Xbox to Component 15pin D-Sub
Monty Burns
Joined
Jul 25, 2005
Messages
3,887
Reaction score
144
Points
809
Age
50
Location
Londoner living in Bahrain
Hey guys, anyone know where I can purchase the above cable? I don't believe the official pack does this as it has three or four "normal" looking cables rather than the VGA type connector I need.
(its to hook up to my BenQ projector, rather than using the composite/scart system i am at the moment)
Thanks in advance!
To hook up to VGA you will need the X2VGA+ which allows you to connect to a normal monitor or projector using the VGA socket. It's not cheap but the quality is extrememly good. http://www.x2vga.com/
Actually THIS is what I need and at 19$US its a lot cheaper than one of those box things.
I'm just buggered if I can find one for sale in the UK! (OR Germany for that matter)
LFCRules said:
Check out the end of this thread, the last few posts, http://www.avforums.com/forums/showthread.php?t=246911. They are in the same position as you wanting a component to VGA cable. There are a couple mentioned on their to buy.
Andy
Now THATS what I am talking about!
Many thanks, gonna order one from Keene right now :thumbsup:
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
