Xbox through my surround sound help please
Discussion in 'Xbox Forums' started by charlieboy789, Jul 29, 2012.
  1. charlieboy789
    charlieboy789
    Apr 17, 2009
    23
    Hi all,
    First off please move if this isn't in the correct section.
    I have an xbox 360 S with a HDMI cable which I have been using through my TV which is a Sony KDL-40BX420. With the xbox I have the the black AV with the red, yellow and white plugs that came with the xbox. I have also bought the xbox HDTV cable ages ago.
    I also have one optical cable, but the sony surround doesn't have on optical on for some reason and only oine HDMI?
    Any help would be brilliant
    Thanks in advance...
  2. Fearns
    Fearns
    Mar 6, 2007
    128
    +10
    i had a similar issue with my old surround sound, the only thing i could do was as below:
    HDMI from Xbox to TV
    Audio dongle from Xbox with L/R Audio out plugged into Audio in on Surround Sound and select Aux in on Surround Sound to hear, not 5.1 surround but bloody loud.
    Upgraded my Surround Sound a few months ago though so now using Optical in on Surround Sound
    Hope this helps
