Xbox through a brand new panasonic th42pe50 plasma!
Discussion in 'Xbox Forums' started by RHCP, Sep 23, 2005.
  1. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Xbox through a brand new panasonic th42pe50!
    What are the best settings 50 or 60 hrz.
    I'm guessing 60, but it looked a bit grainy though. (maybe needs time to run in)
    And then do i set it to widescreen?
    As i said what are the best settings?
    I'm using a scart cable if thats any help
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,499
    London
    +995
    Softmod your xbox so it can run 480p and use a component cable and it should look a lot better. I have the Panny PE30 and it looks fab! :thumbsup:
  3. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Yeah i would do but my screen has only got one component input.
    I've got a very old av amp that hasn't got coponent, fek it i might just go out and buy a new amp!
    Is soft modding easy? :)
  4. Tetlee
    Tetlee
    Jan 21, 2004
    19,733
    Taunton
    +4,348
    This might be of interest to you mate: http://www.darkplanets.co.uk/product_info.asp?pid=836
    I know it's a gamecube thing but it shouldn't make any difference, I'm about to order one so I can imput my Cube, Xbox360 & dvd player into my single Component input of my Sanyo Z1 :thumbsup:
    BTW, is there still the same high risk of plasma burn with modern plasma's, I understood the risk was still high with video games!
  5. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,022
    2
    4
    137
    Garstang, Lancs
    +1,581
  6. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    hhhhhhhhhmmmmmmmm!
    The gamecube thing sounds good for £15
    I think the j.s. box is probably better quality, and pic quality is the name of the game, but for £55 i could put another £40 and get a decent 2nd hand av amp with 2 component connections.
    I wonder if anyone on the forums has used the gamecube box, think i'll post a new thread to see if its any good! :)
    Cheers all
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,499
    London
    +995
    Just beware of cheap switchers, in my experience the quality of the picture can be very bad.
  8. womble9
    womble9
    Dec 28, 2003
    944
    +64
    Not too sure if you've posted that thread yet but fear not :) !!. I bought the exact same one from Play Asia (link here.... http://www.play-asia.com/paOS-13-71-n-77-6-15-component-70-3cb.html ) and it's just fine. I use it to swich between my PS2 / Cube and X box and find that I get no noticable loss in picture quality from either of them (hooked up to my Optoma H56A), nice little piece of kit.
