XBOX SWITCHING TO NTSC, what is easiest way?
Discussion in 'Xbox Forums' started by iainl2005, Apr 15, 2005.
  1. iainl2005
    iainl2005
    Apr 15, 2005
    342
    Glasgow
    +10
    I have a PAL XBOX and a MS HD AV Pack, I know I have to change my XBOX to NTSC in order to get the higher resolution options, does anyone have any advice on the easiest way to do this?. Can you get a switch installed without having to get it chipped?, do you have to get it chipped in that case will it work online?, I cant be bothered booting from a disk everytime I want to use it. I know some of you guys are probably sick of hearing about this, but I am new to the forum and would appreciate your advice.
  2. FGEvans
    FGEvans
    Do a search for hi def on this very forum. The x-box can be soft modded using a special "save" file.
    There was a recent topic posted 2 days ago.
  3. timelimit
    timelimit
    Mar 14, 2005
    46
    I started using the enigma switcher a few weeks back, and now ive gotten into the routine of switching to the unleash x dash making a backup and staying in unleash x to play non live games then reverting back to the standard ms dash to play on live. seems to work fine for me :D
    Do a search for the 'Xbox Hi-def for idiots' (or something like that) thread. very informative.
  4. iainl2005
    iainl2005
    Apr 15, 2005
    342
    Glasgow
    +10
    thanks I’ll check it out. :D
