Xbox & SweetSpot
Discussion in 'Desktop & Laptop Computers Forum' started by mattol, Oct 31, 2004.
  1. mattol
    mattol
    I'm planning my HTPC, no sure I know what I'm doing but hey...
    Is anyone running a Xbox(hi-def out) into sweetspot? What is the quality like? I also wondered how it would compare to to Xbox>VGABox>LCD?
    Secondly, how would you go bout having both the Xbox and Sky Digital connected to the Sweetspot at the same time?
    I have a DVI only LCD panel.
  2. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Hi Matt,
    I am currently running Sky into the Sweetspot via Component/Svideo Sync and the picture is ace. I then run DVI to my projector and VGA to an LCD so I can run both.
    As for running both the XBox and Sky, see my thread in the forum, i am trying to work out the best way to do this with a PS2
    G
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,192
    +1,236
    sweetspot only handles standard definition AFAIK.
    I don't think it even hamdles progressive.
    The main reason for using a sweetspot/dscaler combo is to handle deinterlacing and scaling so a prog scan hd signal kinda misses the point.
    Anyway I'm using one with my Xbox into an HS20 projector and a 37pw5 plasma and its great for gaming.
  4. Kaz
    Kaz
    if you've got xbox HD then run it straight into the component inputs or, as I do for convinience but discovered makes for a better picture, go into the VGA input by converting the component to VGA with an x2vga convertor.
  5. mattol
    mattol
    Not sure I follow. Go straight into the VGA input of what?
  6. Kaz
    Kaz
    the VGA input of your LCD (or in my case Plasma)
