XBox Surround system under £250
Discussion in 'Xbox Forums' started by thewibbler, Jul 23, 2005.
  1. thewibbler
    thewibbler
    Jul 23, 2005
    20
    I have a JVC television with an XBOX which I use for DVDs. I'm looking to get a 5.1 surround speaker package without a DVD player for under £250. It's a small room, so I don't need a lot of power. I was looking at Bose speakers due to their small size, but they make no reference to 5.1.
    Would Bose speakers do? If not, what's the hot tip for sub-£250 speaker systems at the moment?!
  2. colesy
    colesy
    Dec 28, 2001
    721
    +16
    If you don't want to stretch your budget then you can get a fairly good 5.1 surround sound setup for between £50 and £100 from places like PC World. And they normally have all sorts of inputs on the back, optical, coaxial, Cd etc. so you can connect all sorts of devices.
    Have a look on PC Worlds website to get an idea, get one and if you don't like it take it back.
    I use a Packard Bell one and it's fine for me.
    Of course you can also get an all in one sound system made by the likes of Panasonic and JVC for less than £200 Just for an example see HERE . It does have a DVD player but you dont have to use it ;)
  3. -Jay-
    -Jay-
    Jul 26, 2002
    4,882
    Kop End
    +135
    The one colesy posted has a dvd player something you did'nt want ;)
    Try this one Panasonic
  4. thewibbler
    thewibbler
    Jul 23, 2005
    20
    Thanks for the replies! Would Bose do 5.1 systems?
  5. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,159
    +27
    yes bose are very good speakers. I would 100% recomend cantons speakers.... you can order them from germany and save around £200 on a set.
    I have 5.1 setup with my xbox and its amazing !
  6. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,159
    +27
    here ya go mate here are the speakers you want
    http://www.canton.de/www/index.php4?pg_id=14,30,moviecd1,2,en
    I spent many weeks on this forum asking loads of ? about which were the best speakers to buy and every 1 said these.
    the build Quality of them is excellent !!
    you wont find anything better for your price range.
  7. Matt TRD
    Matt TRD
    Jun 28, 2005
    954
    Poole
    +69
    Yeah they look great but won't he still need a seperate decoder?
  8. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,159
    +27
    will just need a AMP to power the speakers
