My xbox has been working perfectly fine for a few years now, however recently it's just stopped working.
If I load up the system, it will instantly try to update, finish updating then reset the console, then tell me I need to update again. The updates take varying amounts of time which is fairly confusing. This morning I refused to let it update and it complained that some of the files on the system were corrupted. I've tried clearing the cache memory, which can sometimes temporarily solve the solution for an hour or two, but beyond that I've no idea what to do short of sending it away for repairs or trading it in for a new consoles.
If it helps, the problems started when I started playing Sonic Generations, where the xbox said it had an update to perform, it's all been downhill from there.
Help?
Help?
