XBox Solderless Mod Chip Adapter
Discussion in 'Xbox Forums' started by Stellavision, Aug 8, 2004.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,288
    Southsea, UK
    +96
    I am thinking of taking the plunge and modding my Xbox, probably in the form of an Xecuter 2.3b lite. I have soldered before but don't feel 100% competant at it so I am thinking of using the XBox Solderless Mod Chip Adapter as found HERE
    Are these any good?
  2. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    Have you considered the Xecuter 2.3b Lite+?
    Solderless as standard and a doddle to fit at that :) Does everything that the 2.3b Lite (Standard) does IIRC and is also cheaper from the outset...
    I also cannot recommend www.baldbouncer.co.uk highly enough for your modding "needs" :)
    K.
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,288
    Southsea, UK
    +96
    I had considered that but unfortunately it is now discontinued.
  4. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,594
    +1,022
    Also Premodded.com may sort out your needs. Slightly cheaper than Baldbouncer I think (although you need to add VAT to the prices on the site). More up to date chips mean you don't need to manually switch before going on Live.
