xbox screen size problem
Discussion in 'Xbox Forums' started by Pantera6, Jan 2, 2007.
  1. Pantera6
    Pantera6
    Jul 27, 2006
    353
    +7
    as the title says.
    had xbox live for few days, popped in halo (only xbox game so far). anyway, said there was an update, i said ok and the screen has shrunk from 16/9 to some other smaller size (not 4:3 though) its still wide screen but not as wide.
    anyone know why this has happened and how i can fix it?
  2. andreig
    andreig
    did you try changing the resolution to a WS one in the System blade -> Console settings -> Screen ?
  3. Pantera6
    Pantera6
    Jul 27, 2006
    353
    +7
    yes. 720p pal-60 widescreen
  4. nick501
    nick501
    May 6, 2005
    7,217
    Walsall, West Midlands
    +782
    thats how halo 1 is at 720p
    try 480p for full screen.
  5. Pantera6
    Pantera6
    Jul 27, 2006
    353
    +7
    it was fine before the update though which is wierd.
    will try it out though
