Xbox & RGB
Discussion in 'Xbox Forums' started by H4r7y, Oct 3, 2004.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    not done this before, but ive just got a rgb scart cable for my xbox, is it just a case of plugging it in to my tv an then its enabled or do i have to do settings either on my tv or xbox at all?
  2. buzlightyear
    buzlightyear
    Oct 8, 2002
    945
    46
    London
    +116
    The only thing you need to do is make sure you plug the RGB scart into the RGB enabled socket on your TV.
    Happy Playing
