XBOX RGB Scart Cable?
Discussion in 'Xbox Forums' started by Indiana Jones, Mar 9, 2005.
  1. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,410
    Bristol
    +10,113
    I know TVs differ but what I type below is how my TV displays.
    I have my DVD Player connected to the RGB enabled socket on my TV and when I turn on the player it cuts in automatically and the letters RGB are displayed in the top right hand corner so I assume this means the TV is detecting an RGB signal coming from the DVD Player.
    When I hook up my Gamecube to the same socket on the TV and use the Scart cable I got for my Gamecube years ago the Gamecube cuts straight in and the letters RGB are also displayed so I assume this means the scart cable for my Gamecube is RGB wired, is this correct?
    Last but not least, when I hook up my XBOX to the RGB enabled socket using what I was told when I bought it is an RGB Scart cable the picture cuts straight in but the letters RGB are not displayed, does this mean the cable for my XBOX is infact not RGB wired? or can it still be an RGB wired cable as the quality look very nice but I really want the best and if my current cable is not RGB wired then I will replace it.
  2. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Its possible that you have a scart which is not fully wired in which case you might be receiving composite signal or even s video. Are all the pins present in the scart or are some missing?
    Matt
  3. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,410
    Bristol
    +10,113
    All the pins are there, would have noticed straight away it they werent.
  4. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    What happens when you switch the cables over?
  5. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,410
    Bristol
    +10,113
    What exactly do you mean?
    I have always unplugged the DVD Player to use the PS2, Gamecube or XBOX and with my new TV the PS2, Gamecube and DVD Player makes the letters RGB be displayed in the corner but because they are not present when I turn on the XBOX I was just wondering whether this means the cable isnt actually RGB wired or if it is a RGB cable and there is a reason why the letters are not displayed.
