Xbox resurrection - media help wanted
Discussion in 'Xbox Forums' started by dUnKle, Dec 30, 2006.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,898
    +2,893
    Spent best part of hour in parents attic and found my original xbox - its been boxed for best part of year and hardly used prior to that
    Its a chipped box - new HD - lots of software type thing - however I have chuff all idea how to get the best from it - it was hardly used once I got it chipped due to personal circs
    Anyway - how (if at all) can I do the following
    (1) Get it to boot into a front end similar to that of the 360 or Media Center
    (2) Play divx and xvid files that are stored on my PC in another room of house
    All I really want it for is a media extender in another room
    If anyone can give me step by step (and bear in mind im an idiot) guide I would be more than happy (and be able to get out of decorating this pm)
  2. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    theres a big thread about softmodding on the forum and a link to download the CASH installer disc, as long as that works with your chip it should be everything you need. i softmodded mine with that disc a couple of days ago. that will let you play divx etc and run emulators and all sorts of stuff
  3. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    You are chipped already so no need for the soft mod.
    Download AID and burn ISO, then run and install XBMC. Or torrent XBMC and FTP into the XBox. Read the XBMC manual to see how to install as a dashboard as this process has changed recently. Also how to share files from PC. If not on AID 3.10, then download 360 skin for XBMC and install to skins directory.
    Also look here for some handy downloads from triplea4uk....inc. a full E drive structure with XBMC set as a dashboard.
  4. dUnKle
    dUnKle
    Jan 1, 2001
    15,898
    +2,893
    Woosh
    Blimey - lot of info
    Well confirmed that my box works - it currently boots into avalaunch - but xbmc seems to be on there and working which is a start
    How do I browse my xbox hd using my pc ?
  5. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    By using FTP. Avalaunch should give you the IP address of the XBox (using a router or cross-over cable connected to the PC). FlashFXP is a recommended FTP client. Username and password are usually both xbox
  6. dUnKle
    dUnKle
    Jan 1, 2001
    15,898
    +2,893
    Thanks all very very much
    Now have my xbox booting direct to XBMC and playing files off my PC upstairs - most happy
    Just one last thing - how do I clean up the "My Videos" section
    At moment I click on it - Find the "UPnP" section - find my network and click on that - then click on folders and then a final click on the folder thats on my PC
    Is there anyway I can just get this folder to show up in "My Videos" straight away ?
    Also - many, many moons ago I purchased the DVD kit and have the remote dongle attached to front of teh box - however no longer got the remote
    Can a Harmony be used and if so what device is it classed as
  7. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    Fast work my man...decorating certainly didn't get in the way of that....
    Harmony can be used. Game Console (with DVD) / Microsoft / XBox.
    I have shared folders on my PC and then edit UserData/sources.xml and add a bookmark in My Videos as this:
    <bookmark>
    <name>TV on PC</name>
    <path>smb://Evo/XBox/TV</path>
    </bookmark>
    <bookmark>
    <name>Films on PC</name>
    <path>smb://EVO/XBox/Movies</path>
    </bookmark>
    Where Evo is the name of the PC and TV & Movies are all shared folders within XBox which is also a shared folder.
    Once you have those working you can delete all the other 'bookmarks' out of the .xml
  8. dUnKle
    dUnKle
    Jan 1, 2001
    15,898
    +2,893
    With you as far as the first <bookmark>
    I use Media Connect - do I just change the evo bit to say what ever it says on my xbox when i click UPnP (Home Cinema PC or similar)
  9. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    Right click My Computer - Properties - Computer Name - Full Computer Name
    Whatever is written there is the name you need to put in the bookmark
    Media Connect? Not sure what that is...
  10. dUnKle
    dUnKle
    Jan 1, 2001
    15,898
    +2,893
  11. scumball
    scumball
    Jan 12, 2004
    6,513
    Harrow - London
    +450
    Oh, my way uses Samba not UPNP.
