Quantcast
Xbox questions?
R
red2003devil
Hi im thinking of buying a mod xbox with an 80gb hard drive.
Can you play online with a mod xbox?
How many games can u get on an 80gb hard drive?
If you can help any1:lease:
kelvin
To answer your first question, "no", you cannot play online with a modified xbox - if you are "caught" by M$, then your machine will be banned from the xbox live network.
As a work around, the majority (all!?) modchips are fitted with a switch which allows you to activate/disable the modchip for use online. Just make sure it's switched off when you want to play on live ;)
K.
Desmo
I've got an 80gig drive in mine and have around 30 odd games on it and still have around 15-20 gig spare.
R
red2003devil
Oh good thank you. I think i will be buying it then
Thanks again.:smashin:
