Xbox, PS2 picture problems on LE32A41B. help!!
Discussion in 'LCD & LED LCD TVs' started by hazzarazza, Jun 12, 2005.
  1. hazzarazza
    hazzarazza
    Hi All, I'm new to the forums and am having problems with my PS2 and Xbox on my Samsung LE32A41B, the main problem is they looked better going through GAME scart cables on my old £150 TV.
    The Samsung has only been used for the PC and DVD's until now, as my old TV decided enough was enough and stopped working completely.
    Could anyone recommend which cables I should use, or is there anyway I can connect component cables to this TV? It has no component inputs, but has DVI and VGA.
    Thanks for any help,
    Razza
  2. paulfoley
    paulfoley
    Sep 17, 2003
    3,407
    Hants
    +107
    For X-Box the answer is easy if not that cheap - get it modded, import a set of the official High Def Component Cables from the USA & an application that switches the machine from UK to NTSC. The picture is stunning !
    For PS2 you could also experiment with a mod & some component cables? I understand however that there are nowhere near as many Progressive Scan games as there are on the X-Box. The RGB Scart output is supposed to be very well implemented on the PAL model, are your leads definately RGB or are they composite (Eugghhhh) ?
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    Hazza said his TV doesn't have Component in (very odd) so he'll need some sort of converter. Luckily I think those do exist, but they'll cost you!
  4. hazzarazza
    hazzarazza
    Yeah thats the only real problem I have with this TV, no component inputs.
    I guessing it will be best for me to just get another TV for my gaming then. Can you recommend anything to use for the Xbox/PS2?
  5. rexuk
    rexuk
    Jun 12, 2005
    45
    bexhill
    softmod your xbox and buy a X2VGA pack from NEOYA and plug it into the VGA port.
  6. Huppe
    Huppe
    Jul 21, 2005
    2
    X2vga does not work with Samsung LE32R51B and I think it will not work with model you suggested, either.
    Signal is not supported, says Sammy.
    Anyway, high def avkit is the answer, component signal looks very nice also.
