Xbox/PS Audio Help
Discussion in 'Xbox Forums' started by sandys, Apr 23, 2005.
  1. sandys
    sandys
    Apr 20, 2004
    89
    Hi there I have just entered into the world of HD playback of my consoles, I am doing this on my PC monitor but it has no speakers so I have to take the L/R audio leads from the component cable into a switch box so I can share my PC speakers with my consoles.
    The problem I am having is that both the Xbox and PS2 do not seem to be amplified when coming through the component cable and even with my speakers on max its pretty quiet, the PC on the otherhand will blow the doors off if the sound is left at the same level as teh consoles.
    Can any of you suggest a solution to my problem, how can I boost the audio from the consoles to normalize the sound between the different machines?
    Sandy
  2. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    643
    +7
    By buying an amplifier.
  3. sandys
    sandys
    Apr 20, 2004
    89
    do you have an example of what I might need and if I can do it cheaply?
