Xbox Progressive Scan
Discussion in 'Xbox Forums' started by BoomBoom, Nov 24, 2004.
  1. BoomBoom
    BoomBoom
    Hi all,
    I have chipped my Xbox and enabled NTSC and the higher res's. I have a US game which supports 720p and when it runs it does look very good. Can anyone tell me how I can definitely tell if it is running progressively?
    Thanks,
    Boom
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Which cable are you using?
    Which TV / Output screen etc are you using?
  3. BoomBoom
    BoomBoom
    I have the component cable running into a Hitachi PD5300
  4. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    The way to tell would be your screen would tell you what it's recieving - somewhere on a menu or info button - don't know the screen but that would be the way to tell.
    A quick comparison by turning 720p off in the dash on your Xbox and seeing if it makes any difference would also show it's working?
  5. BoomBoom
    BoomBoom
    thanks...I will give it a go and see.
    Cheers,
    Boom
  6. JUS
    JUS
    Jan 21, 2003
    3,432
    Plute
    +320
    On my SANYO you can select the input or set it to auto. So if you select 720p is should show fine...selecting 480i should show a dodgy picture.
