xbox power cable
Discussion in 'Xbox Forums' started by la guitars, Sep 9, 2004.
  1. la guitars
    la guitars
    just got myself an xbox - but when unpacking it, i've discovered a two pin power cable :thumbsdow .
    how do i go about getting this to work in the UK ?
  2. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    Do you mean a 2 pin plug? All Xbox's have 2 pin sockets plugs at the console end. If the plug itself is 2 pin then you have probably got yourself an American Xbox, in which case you would need a voltage convertor to step down to 110v.
  3. la guitars
    la guitars
    thanks for reply -
    the two pin is at power end - ie plugs into mains.
    i'm sure xbox is for europe / uk use - the power sticker on back of xbox says "220v-240v - 1.2A" 50hz.
    help !!!
  4. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    If the XBox does say 220v-240 as you describe, then its probably come from a European source.
    If you have any other consoles then just use the power cable from them for the moment. I tend to swap the mains cable between my PS/2 , XBox and Dreamcast depending upon what i'm playing.
  5. DVDcake
    DVDcake
    Jul 1, 2002
    471
    Invading Surrey UK
    +3
    As long as the sticker underneath the xBox says it will run on UK voltage (220-240 volts) then all you need is another lead. I believe the standard lead for cd/radio/cassette players should fit which is available here Maplin Electronics
    You may also be able to find it at a local electrical shop although a quick search of the Dixons web site turned up no leads (no pun intended) :) .
    Maybe they have it instore or you could try Woolworths or Robert Dyas.
  6. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    Or if you want the cheap option, just cut off the plug and replace it with a UK 3 pin if you have one spare.
  7. DVDcake
    DVDcake
    Jul 1, 2002
    471
    Invading Surrey UK
    +3
    :oops: Forgot about that option. It is the cheapest though even if you have to buy a new plug it will still work out cheaper than a new lead provided you can wire a plug of course. :)
    All hail Stellavision the ultimate champion of KISS (Keep It Simple Stupid). :clap:
