Xbox poor visual with pixel plus???
Discussion in 'Xbox Forums' started by deadscoob, Aug 23, 2004.
  1. deadscoob
    deadscoob
    Mar 19, 2004
    10
    Can't seem to get a decent picture running my xbox on a philips pixel plus set. Have mucked about with all the settings but the picture can either have bad smudging or lines within the graphics, especially on characters. Thought it may be the std scart cable, so bought an advanced one and no different.
    It was fine on my old sony tv - are there any peculiar settings when using pixel plus tvs, or is it a generic problem caused by the set?
    TV is fine in normal terrestrial, satellite or dvd viewing......
    Thanks in advance
  2. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Does Pixel Plus run at 100Hz? That could be what's causing the poor picture.
  3. Squiffy
    Squiffy
    May 23, 2002
    12,609
    Ashford, Kent
    +5,787
    I've got a 100hz Pixel plus TV (the 9607) and I have no problems such as you are describing.
    I'm using an advanced Scart into the RGB socket.
    Maybe its one of your settings? I tweaked mine a fair bit when I got it with all the Active control gubbins and all that. A search back on the TV forum could be useful if you need to do the same...
  4. rubberducker
    rubberducker
    Aug 10, 2004
    345
    i have got my xbox connected through Advanced RGB on my Phillips Pixel Plus and the picture has always been terrible. so much so i am never going to buy another phillips product.
    is there a way to make this better? what should i search under in the TV forum.?
  5. Pooon
    Pooon
    Dec 26, 2002
    7,413
    Canterbury, Kent
    +1,011
    Can you switch off the pixel plus processing? I know it can be done on some Philips sets. Also some sets have a 'demo' mode where it shows half the screen which whatever 'picture enhancement' system the tv has and the other half with all post processing modes turned off, try running this with your xbox on to see what 'mode' will give the best results
