xbox & plasma?
Discussion in 'Xbox Forums' started by baccus, Aug 17, 2004.
  1. baccus
    baccus
    This might be a silly question but is there a way of viewing my xbox on my new Panasonic TH37PB30 plasma in a higher quality than with the scart lead that comes with the xbox? I have a PC input on the tv, does this mean i can buy some sort of convertor and watch in higher quality thru this?? I'm new to all this so don't laugh if i'm talking thru my backside!!!
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
  3. Brigadeer
    Brigadeer
  4. baccus
    baccus
    Thanks, I will be after one for the weekend.
  5. baccus
    baccus
    I've looked everywhere and can't find one on the net anywhere?? I'm restricted slightly because the PC i'm using is at work and filters any sites with 'game' in the title. Any ideas where in the UK i can go, that delivers within a day or so??
  6. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
  7. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    Please correct me if I am wrong, but isn't the High Definition feature only supported in the NTSC format? You need to modify PAL units to use HD connectivity, with all the good things that go with this such as warranty and XBL issues.
  8. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    As above, High Definition is disabled on PAL xbox's - if you have to have it, you will need to either:-
    a) Obtain an NTSC machine
    or
    b) Go down the modchip/exploit route
    Sorrt to be the bearer of bad news... :(
    K.
  9. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    Actually - I thought you could use the high def. pack - but you won't get a high def picture - but it should be better than using scart (as it's component).
    Correct ????
    ZedZed
  10. dUnKle
    dUnKle
    Jan 1, 2001
    15,480
    +2,383
    Well as a long time anti-chipper I relented last week and fitted one of those non solder chips
    My advice to anyone with a plasma and an XBox is to get your box chipped and get the high def kit
    Whats the point of spending £2000+ on a decent TV and not making the best use of it
    The graphical difference is outstanding - fantastic - its like going from 640 res to 1024 on a PC
  11. Damnyoureyes
    Damnyoureyes
    Jun 17, 2004
    46
    The hi def will output 525i/480i i think on it's own for PAL xboxes to get the 480p and above you need to mod either chip it or via a soft mod.
    You can soft mod your XBox via one a game save hack have a look on xbox-scene
    http://www.xbox-scene.com
    www.lik-sang.com
    for the high def pack and a usb lead so you can plug it into your pc and make your memory card an action replay card.
    transfer the saved game with the hack onto your pc go into the game load the hacked saved game file and then run the video changer.
    You can still use live no problemo
    I'm just in the process of doing this all at the moment will get back to you all when I'm done but even just the high def pack makes it look better more detail and colours are better.
  12. baccus
    baccus
    I've got my xecuter lite chip in the post this morning and will be fitting tomorrow and will be ordering my hi def pack for the weekend. Will this chip enable me to use the hi def pack or will i have to upgrade the OS for EvolutionX so that the settings can be changed. Starting to get very confused*?!!*
