Probably a stupid question but nevertheless i dont know the answer I have a Panasonic Plasma 42" PA20 an Xbox and a Pioneer DV990 surround system How do I wire the xbox to the DVD system so that I can here the X box through it rather than the rubbish tv speakers? Thank you in advance
You need an advanced scart connection (usually about £20 from any gaming high street shops) which has an optical out connection on it.
Scart should go straight to the screen for the best picture. If you have a US Xbox you should consider ordering the High Def component cable from dvdboxoffice.com
The scart connects the Xbox to your plasma, and you then need a separate optical cable to link between the connector on the scart lead to your AV amp.
