xbox - PIO AX5I-S video switching
Discussion in 'Xbox Forums' started by Digger, Nov 27, 2004.
  1. Digger
    Digger
    Dec 31, 2003
    4,204
    World Wide Supermarket
    +206
    I have a problem which i hope someone may have an answer to. I have the above mentioned Pioneer receiver with DVD and freeview (Netgem) connected via component inputs. the Pioneer is outputting via component to a projector. The Pioneer fails to output my Xbox when it is connected via S-Video. I am using the official Microsoft Advanced AV Pack with supplied s-video lead. It will work if i disconnect Pio's component-out leads and instead use an s-video as the video-out to the projector...but thats a cludge i dont want to carry out each time. The manual suggests that it should work with an s-video signal...
    anyone got any ideas
    cheers
    Dave
  2. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    It would surprise me if it did actually do what you're hoping it will do. Not many receivers will actually convert a signal - normally they will just pass it on, much like what you are describing when you change over your wires.
  3. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,914
    38
    UK
    +7
    The updated AX5ai will upconvert but not the AX5i. You either need to run 2 leads to your PJ or get a component AV kit for the Xbox. Pain in the arse I know.
    Great amp though!
  4. Digger
    Digger
    Dec 31, 2003
    4,204
    +206
    thanks guys...and there was me hoping my pio would up-convert.
    now i have a pathetic excuse for an upgrade!
    cheers
    dave
