Xbox PES4 Real Names?
Discussion in 'Xbox Forums' started by adrian3221, Apr 4, 2005.
  1. adrian3221
    adrian3221
    Dec 17, 2003
    717
    London
    +42
    Does anyone know where I can get a disc which enables me to update PES4 with the real player names???
    TIA.
  2. Pooon
    Pooon
    Dec 26, 2002
    7,126
    Canterbury, Kent
    +731
    Not as simple as that i'm afraid. You will need a Max Drive memory unit(or similar) and the patch that has the update with the player/team names and kit from here: PesFanPatch then once you have the file transfer it to your Max Drive, plug that into your xbox, load PES4, go to the edit/options(can't remember which) and roberts your fathers brother, all the names and kits on your xbox.
  3. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    Also you can get many flavours of option file. Locked, unlocked (including 6* difficulty), british teams (championship etc), use Championship Manager stats.
    etc
  4. adrian3221
    adrian3221
    Dec 17, 2003
    717
    London
    +42
    Thanks for the help guys, feel a bit miffed that I have to spend £15.00 on this max drive thing that Im only gonna use once! But I really want the proper names, kits, etc. Maybe I'm being naive but I'm surprised that you cant get this info on disc then save it on your Xbox????
  5. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    Some of the kits are stunning, and rosters good. You'll be SO pleased.
  6. dubledene
    dubledene
    having trouble getting the disc to run on my pc where can i dl the drivers??? for the x box max drive??
  7. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    dubledene, you have pm
  8. dubledene
    dubledene
    cheers john cd comes up with
    16 bitwindows subsystem????
  9. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    dubledene, check your email
  10. dubledene
    dubledene
    god this is doing my head in, cannot get it to do anything, thanks for the file john what am i supoposed to do with it!!!! have mucked about a bit, but still pops up about the 16 bit sub system what is this???
    can i run it on xp it says that i can, help !!
  11. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    I use it on XP.
    1, Make sure the max drive is not connected
    2, Install the software
    3, Connect the maxdrive
    I think that's the way.
    I just used the files I sent (I double-clicked setup.exe) and it worked fine.
    There are two parts to this. Firstly it installs the software (front end), then it installs the drivers which recognise it. Again, I think. Have you tried the usual reboot etc.
    Depending on when you started trying to install in the first place, you COULD set the system back to a previous restore point prior to first time you tried (it doesn't touch 'My Documents' - everything else at risk).
  12. dubledene
    dubledene
    still no go going mad wont even look at the file you sent me john, is it anything to do with the 64 bit chip i got????
  13. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    64-bit ? I would have thought that windows could handle that kind of stuff and not have an issue. Did you unpack the zip file I sent, and then try and run the setup.exe?
    Incidentally, my new max drive arrived today (other stopped working as max drive and only worked as normal 16mb usb drive - weird).
    New one, I put max drive in usb of my laptop (first !!! cos it told me to), then I ran setup.exe, it loaded max drive s/w and drivers, and 30 seconds later I was dragging saves back and forth.
    I can't begin to understand why your is not working. My new one worked first time.
  14. adrian3221
    adrian3221
    Dec 17, 2003
    717
    London
    +42
    Does anyone know the cheapest place I can find one of these max drive things? Dont mind if its 2nd hand.
  15. dubledene
    dubledene
    give me a few hours and i might be selling 1!!!!!!
  16. adrian3221
    adrian3221
    Dec 17, 2003
    717
    London
    +42
    Nice one! keep us posted.
  17. barrybarryr
    barrybarryr
    Sep 26, 2004
    728
    +19
    Can someone please explain what a max drive thing is and how it works?
    I would like real kits etc on pro evo aswell!!
  18. dubledene
    dubledene
    got it working is there anything else i can do with the max drive??
  19. watchinthewheel
    watchinthewheel
    this is a max drive.
    im confused why do you have to use the maxdrive though? cant you just ftp it over? :confused:
  20. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    417
    +10
    You can FTP, nothing stopping you, but it's trickier for the average user.
