Xbox: Pal 50 Or Pal 60?
Discussion in 'Xbox Forums' started by Tesla, Jan 29, 2004.
  1. Tesla
    Tesla
    Dec 9, 2003
    936
    Bristol, UK
    +32
    I have just got a new TV. Panasonic TX28PS12.
    Its 100hz.
    Is it better to have my XBox in Pal 50 or 60? Or wont i notice a difference? I cant seem to see a difference.
    I realise Pal60 allows for a higher Frame rate but Halo doesnt get on well with this.
    \\Chris
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Basically all it means is this (as far as i'm aware)
    Most games are developed in either Japan or the USA. Obviously they use NTSC at 60hz. Most games when they are converted to pal aren't optimised at 50hz, so suffer from slow-down, which is obvious in some games.
    Other games such as Halo work better at 50hz.
    I have my xbox set to 60hz automatically as generally this is what most games are optimised at (AFAIK).
    Hope my (very) limited knowledge is of some help! :D
  3. zerolight
    zerolight
    Jan 29, 2004
    239
    Glasgow
    +10
    Halo looks marginally better in 50hz. But its the only game that does. I leave mine locked in 60hz. Many games are abismal if not in 60hz.
  4. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    I'm the same as Games Guru. I just leave it set for 60hz as default. I've looked for a difference and can't see it myself but assume 60 is better than 50 on the odd game.
    Panic
  5. -Spike-
    -Spike-
    May 17, 2001
    1,460
    E.Sussex
    +171
    Me too.
    The only drawback with Halo is it stutters occasionally in 60hz which for me didn't spoil it at all.
  6. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    It'll be 120Hz for PAL60 or NTSC games, or R1 DVDs; it's "only" 100Hz for regular PAL (PAL50 and R2 DVDs, etc.)
    StooMonster
  7. Tesla
    Tesla
    Dec 9, 2003
    936
    Bristol, UK
    +32
    Is it safe to run at this? Is it within specification?
    \\Chris
  8. FoxyMulder
    FoxyMulder
    You should switch those processing features off as i believe they ruin the picture quality and there isnt a 120hz option on UK televisions is there ?
    Set ur X Box to 60hz and ur television to 50hz and switch the 100 hz processing off you will find it performs better.
  9. gingercat
    gingercat
    Nov 19, 2002
    489
    Lancashire, UK
    +26
    I'm sure that 100Hz tvs only double scan (or whatever you call it) when using a 50Hz source, so running a 60Hz source will shown as just that, 60Hz.
  10. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    Let me know how the xbox runs on this TV in pal60 mode please. My bro is interested in this set and would like to know how xboxs in 60hrz mode runs on it. Thanks:)
  11. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    I find on myTosh 36zp38, and my older tosh, that, if the xbox is set to pal60 it will change to this if the game supports it.
    I can tell because the TV graphics (volume etc) look taller, on pal60 has there are less scan lines.
  12. Tesla
    Tesla
    Dec 9, 2003
    936
    Bristol, UK
    +32
    Forgot all about this thread.
    I have been playing around today and so far I have come to the conclusion that setting the XBox @ 50hz gives a sharper picture.
    I dont know if or how you can switch the 100hz processing off on my TV.
