Xbox over NTL - new service
Discussion in 'Cable TV & Virgin Media TV' started by graham.myers, Jan 30, 2003.
  1. graham.myers
    graham.myers
    NTL have announced a new services specifically for X-Box users.
    It upgrades to include a 2nd IP address for your x-box and a router
    http://www.ntlhome.com/xbox/
  2. CarlB
    CarlB
    Jan 8, 2001
    1,292
    Cambridgeshire
    +222
    Graham,
    The service is not required if you use a router as you then only need one IP address in the first place. This offering is for people who are *not* using a router and are having problems due to the fact that ntl will not allow two MAC addresses on the same IP connection any more.
    My advice is to buy a router as you can easily pick one up for the adiditional price of this service over 12 months. I have the standard ntl 600K service and use a Linksys wireless router with XBox Live, it works like a charm.
  3. graham.myers
    graham.myers
    thanks Carlb, I assumed that would be the case - I was just looking at the various options as I have to go NTL cos I'm too far away from the BT exchange.
    Now you've mention a wireless router that works on NTL, I'm happy.
    Does it come with a firewall or do I still have to use the software version NTL recommend?
  4. CarlB
    CarlB
    Jan 8, 2001
    1,292
    Cambridgeshire
    +222
    Graham,
    Check your other thread for Linksys details. I use Norton Personal F/w on both PC and Mac, though the router comes with configurable ZoneAlarm f/w capability. Not sure if this would then affect the XBox service though - that is why I leave the router open and protect my PC/Mac at the software level.
  5. graham.myers
    graham.myers
    cheers again:smashin:
