Xbox optical audio out
Discussion in 'Xbox Forums' started by waldopepper, Aug 9, 2003.
  1. waldopepper
    waldopepper
    Jun 29, 2003
    122
    UK
    +10
    I have bought the better official xbox scart and an optical audio cable to plug into it, but my new amp has a co-axil audio input. Does anyone with this setup know the easiest way to hook this up?
    I guess either a special lead from the scart to coaxil, or a converter?
    thx
  2. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    you need one these
    Optical to Coaxial Digital Audio Convertor
    Bigger Picture
    Converts the optical digital output from a Toslink to an electrical S/PDIF coaxial signal. The unit is just 72 x 48 x 22mm and features a standard Toslink input socket, a phono output socket and a DC power socket. Power requirements are 6V 250mA, supplied by the plug-in mains adaptor included.
    · Converts optical (Toslink) digital signals to electrical (phono)
    · Includes plug-in mains power supply
    · Solves problems connecting digital audio equipment with incompatible connections
    · Ideal for Home Cinema and hi-fi use
    stock no QN17T
    goto http://www.maplin.co.uk
    Boogie man :cool:
  3. waldopepper
    waldopepper
    Jun 29, 2003
    122
    UK
    +10
    Ah great. Although I was just about to order this when I read the text more carefully - you've given me the product code for the opposite one (coaxial to optical). I think its QN18U that I'm after - optical to coaxial.
    Ordering now.
    thanks for the help
    w
