Answered Xbox One X 4K problems with TV & AV receiver.
Discussion in 'Xbox One' started by Secondhand, Nov 8, 2017.
    1. Secondhand
      Secondhand
      Sep 26, 2017
      4
      Kettering
      Hi. So I’m going through the settings of my new Xbox One X and look at picture settings. It says my TV doesn’t support HDR10 & 4K 10-bit at 60Hz. I know my tv does.
      However to the left it has a warning sign that if connect via a AV receiver, it may effect the results.
      I know my AV receiver supports HDR10 pass through and native 4K picture.
      My tv is the LG OLED C6.
      My Av Receiver is a Yamaha RX-V581
      Anyone know what I should do. Any settings I need to change on the receiver. The Xbox is connected to HDMI 1 input.
    2. Best Answer:
      Post #19 by Setitie, Nov 11, 2017 (1 points)
    3. regurgitator
      regurgitator
      Jan 2, 2009
      28
      3
      +5
      If you connect it to your tv without using the receiver do all the boxes come up with a green tick ? Also on some tv's you have to choose a specific hdmi port for the 4k uhd to work. On some tv's you have to turn on the 4k for the hdmi ports too.
    4. Jonah66
      Jonah66
      Oct 16, 2017
      24
      Weston super mare
      +8
      I think you need to turn HDMI deep colour on on the LG
    5. Secondhand
      Secondhand
      Sep 26, 2017
      4
      Kettering
      Hmm. How do you do this??
    6. Secondhand
      Secondhand
      Sep 26, 2017
      4
      Kettering
      I need to try this tomorrow.
    7. Jonah66
      Jonah66
      Oct 16, 2017
      24
      Weston super mare
      +8
    8. JimboH
      JimboH
      May 29, 2012
      517
      Aberdeen
      +297
      I think there is also a setting on the yamaha rx-v581 you need to make sure is correct, it's been a while since I set mine up but I'm sure I remember something.
    9. Secondhand
      Secondhand
      Sep 26, 2017
      4
      Kettering
      Could you let me know if you remember please :)
    10. JimboH
      JimboH
      May 29, 2012
      517
      Aberdeen
      +297
    11. JimboH
      JimboH
      May 29, 2012
      517
      Aberdeen
      +297
    12. Secondhand
      Secondhand
      Sep 26, 2017
      4
      Kettering
    13. steb9780
      steb9780
      Oct 6, 2005
      835
      5
      46
      Preston
      +187
      Yep had the same thing to do with my 481, why Yamaha didn't have this on from the factory beats me.
    14. Setitie
      Setitie
      Nov 11, 2017
      7
      4
      Edmonton
      It was a cable issue, now fixed. Sorry for the bother. :)
    15. Setitie
      Setitie
      Nov 11, 2017
      7
      4
      Edmonton
      One thing of note (probably super important) is that I can't get either my PS4 PRO or XB1X to work on MODE 1 only 2. My HDMI cable is a Ultra Slim 18Gbps Active High Speed HDMI Cable from Monoprice. I guess that's my problem it has to be, as JimboH said, on MODE 1 but when it is no picture.
    16. Setitie
      Setitie
      Nov 11, 2017
      7
      4
      Edmonton
      I just got my Xbox One X today and hooked it up to my Yamaha RX-V581 receiver. I'm having the same issues as Secondhand. I followed JimboH's instructions on 4K HER mode and yet for me I'm still having issues as did SH. If I plug my XB1X directly into the TV it works. Looking forward to whatever help you may suggest. Thank you
    17. Secondhand
      Secondhand
      Sep 26, 2017
      4
      Kettering
      Have you updated your Yamaha firmware receiver? Same method like the Mode 1 & 2 but keep scrolling along til it says update.
    18. Setitie
      Setitie
      Nov 11, 2017
      7
      4
      Edmonton
      I haven't but will do that just to be up to date. Good advice, thank you
    19. Dan201
      Dan201
      Mar 5, 2010
      4,018
      +586
      I had to connect my Xbox to my TV directly and use ARC. Marantz 7011.
    20. Setitie
      Setitie
      Nov 11, 2017
      7
      4
      Edmonton
      Best Answer
      A temp fix to the Flickering seems to be switching inputs and or turn off & than on
    21. Setitie
      Setitie
      Nov 11, 2017
      7
      4
      Edmonton
      Further to the black it happens on all connected devices (PVR for example)
    22. Setitie
      Setitie
      Nov 11, 2017
      7
      4
      Edmonton
      It's working with the HDR but now it does this thing where the screen goes black then comes back then so on. Any thoughts on that? As SH suggested I did run the update on the receiver
    23. pavloPL
      pavloPL
      May 27, 2013
      59
      Romford
      +16
      Well my Xbox One X does not work perfectly with my receiver as well. I have an Anthem 1120 and when Xbox connected to the receiver it sends 8 bits only instead of 10 or 12, but when passthrough it sends 12 bits, annoying. And Atmos does not work as well... super anoying.
    24. next010
      next010
      May 29, 2005
      10,556
      163
      +2,045
      Make sure the firmware of the receiver is up to date they released a software upgrade on their download page last august and in the change log it mentions improved HDR support.
      If you have already done this and are still not getting anything than it's a HDMI handshaking issue (which may also explain Atmos not working) that can only be resolved by either Microsoft or Anthem. Getting Anthem to fix the issue on their side would be faster than trying to get Microsoft's attention on it so I'd contact Anthem first.
      As far as I know Xbox doesn't gain anything from 12-bit it's just there as future proofing, the GUI and all games/movies are in 8-bit, the only time 10-bit gets invoked is when HDR is in use, I could very well be wrong but that what I've read over the years.
    25. Secondhand
      Secondhand
      Sep 26, 2017
      4
      Kettering
      Another option I was thinking when I was struggling was direct HDMI from Xbox to TV for picture and then optical cable for audio from Xbox to AV Receiver.
    26. Nepheler
      Nepheler
      Dec 2, 2014
      71
      11
      LA
      +4
      I have the Xbox One S which can support the 4K videos, I don't want to use the Xbox One X. Playing 4K videos on Xbox One X is not a easy thing.
    27. pavloPL
      pavloPL
      May 27, 2013
      59
      Romford
      +16
      Thanks next010, I did contact them both for now see if got their attention and if my case is a single of more common. Regards firmware yes it is running with this latest one. 10bit I need for HDR which makes more sense for X model.
    28. pavloPL
      pavloPL
      May 27, 2013
      59
      Romford
      +16
      Yeap that is what I am doing now but I am limited to Dolby Digital 5.1 over optic cable, far away from ideal Atmos sound which sends only over HDMI.
    29. cjmilner
      cjmilner
      Aug 19, 2007
      148
      York
      +22
      I'm also having issues with my Xbox One X running through my receiver and not getting full 4k and HDR. I have a Pioneer SC-LX59, and an LG B7 OLED tv. I've got the deep colour settings all done and I know the TV accepts HDR through from the receiver as my Ultra 4k player works fine through it, but just can't get the new Xbox to work properly through it. I'm using the cable that came with the Xbox, and have tried multiple HDMI inputs on the receiver but to no avail. I've updated to newest firmware too. Any ideas??
    30. Secondhand
      Secondhand
      Sep 26, 2017
      4
      Kettering
      Are all the HDMI 4K capability?
    31. cjmilner
      cjmilner
      Aug 19, 2007
      148
      York
      +22
      I'm not entirely sure, but using the BD HDMI port that my 4k player works with still doesn't fix the problem.
