Triggaaar
- Joined
- Apr 13, 2003
- Messages
- 10,158
- Reaction score
- 3,533
- Points
- 2,053
So I plug the Xbox in to my old plasma's DVI socket (not HDCP compatible), switch everything on, and the it works... at 640x480!
After trying and failing with 720p and 1080p output settings:
'We recommend you get a new tv'
**** you pal!
Anyway, I goes into my plasma advanced settings ('cos I is advanced), and change the input mode from 2 to 1, try 720p, and bingo, we're on.
So 720p is working, but it's not ideal - my plasma is 1280 x 768, and it's pixel to pixel mapping, meaning I get small black bands top and bottom. I'm not sure I can do anything about it.
Still, for anyone with a non HDCP tv, it does work.
**** you pal!
