Xbox one & Samsung 40ju6000 settings for quality
Zagroo
Hello, i have a few questions about configurations my tv. Sorry for me english.
Do i need set 24,30 or 36 color depth?
What about Rgb, Full or Limited?
Does Game Mode degrades graphic quality? And i need set hdmi name to pc?
I dont have lag but i care about graphic.
Indiana Jones
You want both the XB1 and TV to have a Limited RGB level as the Full level is screwed up on the XB1.
Indiana Jones
You asked which RGB level to select (Limited or Full) and you want both the RGB setting on the TV and XB1 to be set to Limited as the RGB Full setting on the XB1 is broken.
If one was set to Full and the other to Limited it would be a mismatch and either make the image too dark or washed out.
Zagroo
Ok thanks, i gonna try do this later. What about the rest? Color depth in xbox settings, should be 24?
And i read somewhere that if you have 4k tv then you have to change hdmi name to pc because if not it will be a bad for quality graphics. Thats true?
So i have to change RGB full in my TV aswell? I dont know that where is this options in my tv but i gonna check later
Indiana Jones
I never changed the color depth setting on my XB1 so can't help there and afraid I have no idea about renaming the input, perhaps you would have better luck in the TV section?
