XBox on the side
Discussion in 'Xbox Forums' started by CatManDo, Nov 6, 2004.
  1. CatManDo
    CatManDo
    Nov 5, 2003
    1,791
    South Yorks
    +249
    I am finally an XBox owner! My missus bought me one today for my birthday!
    The only problem is I have no space!
    My question is can the XBox be stood on its side like the PS2 can be?
    Is there a problem doing this because of the CD tray or because of air ventilation?
    TIA
  2. broona
    broona
    Aug 26, 2004
    5,625
    Hexham
    +689
    Think you'll have a problem with both, almost sure DVD's won't run properly like that! :eek:
  3. Del Boy Smiffy
    Del Boy Smiffy
    May 4, 2004
    6,396
    Yeovil
    +415
    Nothing will run on its side mate, your gonna have to make some room.
  4. allanp
    allanp
    Jun 28, 2004
    1,063
    63
    +108
    My mate has his on it's side and it's fine. You just have to be careful when inserting and removing discs.
  5. CatManDo
    CatManDo
    Nov 5, 2003
    1,791
    South Yorks
    +249
    Thanks guys :(
    Also as a newbie, is it true you can copy the games you are currently playing to the hard drive? If so how?
  6. Del Boy Smiffy
    Del Boy Smiffy
    May 4, 2004
    6,396
    Yeovil
    +415
    You'll need to get your Xbox modded mate.
  7. barneybelly
    barneybelly
    Jan 5, 2002
    183
    When u say modded what do u mean?
    i have had my x-box for a year now and was thinking of getting it chipped....is this the same thing?
    I'm not sure about the hard drive etc.....as am not sure what it does...would love someone to explain to me!!
    I am a bit worried about getting mine done though....
    My nephew got his chipped last week and the "games" he got with it work fine but any original that is put in seems to freeze when loading up....is that a known problem or just with that chip?
    Will this affect x-box live at all?
  8. Rob20
    Rob20
    Jul 3, 2004
    3,132
    +675
    Mod is mainly via a chip, but also software. Chipped machines will be permanentkly banned from Live! if detected. Though some chips can be disabled.
  9. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,147
    41
    NW London
    +17
    if the games that he buys crash when loading then the chipper has done a v poor job. They have set the XBOX region to USA (thus enabling Hi-Def) but they also changed the game region to USA, this means UK games wont work in it (newly bought ones at least).
    I would definitely not run the xbox on its side, mostly coz the sides are an important intake for the fan cooling the Xbox... Its not too much space to ask... :)
