xbox on PWD8?
Discussion in 'Plasma TVs Forum' started by Ticsmon, Nov 2, 2005.
  1. Ticsmon
    Ticsmon
    whats the best way to connect my xbox to my PWD8 got the sky going into it via scart and sound via VGA?
  2. steve-o
    steve-o
    Jun 14, 2005
    408
    +5
    The best way would be component, which is available via the VGA port or by buying a component input terminal.
    Terminal would cost about 70quid and the price of a component cable. To get it going through the VGA port, you need to make your own cable! :D
    The guides Here.
    Good luck, whatever you choose ;)
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    not sure what you mean about sound via vga?
  4. nak
    nak
    Dec 20, 2004
    146
    Birmingham
    +12
    Got my Xbox linked up to VGA with a nice little box I picked up on eBay (£30)
    There doesn't seem to be any signal loss, and it also has a Toslink port for the sound!
    Have a mooch around, if you're persistent you will find the right box.
