XBOX Not Keeping Time/Date
Discussion in 'Xbox Forums' started by Norman, Dec 26, 2002.
  1. Norman
    Norman
    Jul 14, 2000
    1,642
    116
    Herne Bay
    +512
    Just got one quick question about my new XBOX. Is it normal for it to reset the time and date when the power is switched off for a while.
    It keeps all the other settings (video mode etc), but not the time/date. If I leave it plugged into the mains with the power switched on (but the XBOX off), then it does keep the time/date.
    Is my unit faulty?
  2. CarlB
    CarlB
    Jan 8, 2001
    1,300
    Cambridgeshire
    +226
    This is normal behaviour. It mentions it in the instruction manual on my US XBox.
  3. Norman
    Norman
    Jul 14, 2000
    1,642
    116
    Herne Bay
    +512
    That's a relief. Thanks Carl.
  4. Annatar
    Annatar
    Funny you should say that. This happens to mine all the time and its annoying!
  5. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    It's if you switch it off at the mains I think.
    There is no internal clock memory, thats what I was told by MS anyway!
  6. CarlB
    CarlB
    Jan 8, 2001
    1,300
    Cambridgeshire
    +226
    Yep, leave it switched on at the mains (or plugged in, whatever) and you will have no problem.
