Rob100
Hi all,
I don't normally frequent this part of the forum as consoles aren't my thing TBH, but our son is just about to turn 4 and having played on consoles round a friends he now tells us "I want to play games on the tele".... (bottom lip sticking out...). The games on Cbeebies web site are a bit boring for him now.
The "TV" would either be a 4:3 21" CRT (composite, svideo and RGB) or a Panny PW5 plasma (RGB, svideo, component or VGA) depending on which room he was using it in.
I plan to look at getting something second hand. I have read some things on the Xbox in the past, but am a little vague so some advise needed please
1) What's the best "chip" to get? I would like to be able to play back-ups as I would rather that he didn't have the original discs as you know what kids are like...
2) Can you back-up games onto the hard drive? If so this could be easier for him - he wouldn't need any discs then.
3) Being able to play xvids from the hard drive would be handy.
4) I seem to remember reading that some drives are better than others for compatabilty with back-ups?
5) What extra cables would I need for RGB, component or VGA connection. I assume the cable which comes with it as standard does svideo?
I probably have more questions, but this should get the ball rolling...
Thanks in advance.
Rob.
Thanks in advance.
Rob.
