Are you asking about console or controller? Your post isn't particularly clear.
If you're asking about console out of the two you should go for the Xbox One. The 360 is an obsolete console now and not really supported any more whereas the One is the current model.
Old consoles do have a large range of games and can be had cheaply, but they're going to be more prone to failure now due to their age. You can only buy used as they're not made any more, but you've no idea whether it will last a week or a year. Also some of the online servers for games have been shut down so some games may not be fully functional if you want to play them online.
The One will obviously be more expensive, but it's still current so gets regular updates and there are new games coming out all the time.
Personally I'd buy new as you never know how a used console has been treated by its previous owner. Here in the UK you can buy used from a retailer which will come with a retailers own warranty, but they're not much cheaper than buying new.
As for the controller, you buy the one that's compatible with whichever console you choose.
