XBox multiregion without chipping
Discussion in 'Xbox Forums' started by drunkenmaster, Feb 5, 2005.
  1. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,569
    The Shaolin Temple
    +43
    I read somewhere on this forum that the UK PAL Xbox can be multiregioned without chipping
    Can anyone enlighten me?
  2. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    I'm fairly certain the answers no. I got an American dvd handset and dongle to set my UK box for R1 disks and that's now apparantly locked in.
    There was talk in the early days of a disc coming out from Datel i think but that never materialised.
  3. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,240
    Bristol
    +8,557
    It is possible to make your xbox multi-region and run import/backup games by using the exploit but I have been told its not as good as getting a chip installed but if you dont want to open up the console then its probaley the other method you will find.
  4. Mose
    Mose
    Dec 1, 2004
    1,629
    Aldershot
    +149
    I've heard that this is done pretty much the same way as the original PS1 was modified. My son has done both his PS2 and Xbox without having to modify them in any way at all, and apparently this is done my "tweaking" with the inside of the transport. Easier on the PS2. I will ask him how he did it when I see him!
  5. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,146
    41
    NW London
    +17
    Assuming you refer to DVD multiregion... It depends what you mean by chipping... If you do not want to put a chip in the xbox then yes it can be done. However, the only way is by changing the bios and hence making it impossible to go onto live. The MSDash can be hacked to allow multiregion code but as soon as you put the bios back to normal, a modified MSDash will not run.
    Basically the easiest way is to get it chipped, you can still go on live and do everything you are used to, just you have a HUGE list of new options!!!
  6. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    A friend of mine soft modded my XBox & I can play multi region discs no problem ,I will check tomorrow to see what the program is called..............Jim
  7. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,569
    The Shaolin Temple
    +43
    Thanks for all the info peeps.
    Chipping it will be
  8. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,569
    The Shaolin Temple
    +43
    Hey but jimcarney if you know the biz then it will be mighty helpful!!
  9. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Extremly helpful. I could finally stop useing my X-box for R1 dvd's and my PS2 for R2's and just use the X-box and ditch my useless Sony machine :)
  10. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,146
    41
    NW London
    +17
    General Panic, just chip the xbox, it will cost you £35 if you do it yourself and £50 odd if somebody else does it for you. You easily get this back on the huge list of new things the xbox can run. XBMC is worth the £50 on its own!!!!
  11. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Ooohh , i feel i would like the benefits of chipping myself but what if something went wrong. Is soldering not required ? . Techy things , like opening my xbox makes me very nervous. Don't live in an area where others doing it for me are an option either.
  12. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Hi Drunken master sorry for the delay the program is: DVD-X2 Dongle Free DVD Player ,I think if you do a search on Google you should find it !..........Jim
  13. daz500
    daz500
    Oct 10, 2004
    47
    Belfast
    it's a shame your Halo gamesave got wiped :(
