Xbox multi player link up HUB ????
J
jerkyboy
What sort of HUB do I need for me the link up 4 or 5 Xbox's ?.
Do I use the same cables as for direct link between 2 xbox's.
Thanks for any info.
Fonzerelli
a switch will work better than a HUB but any hub will be fine, you need straigh through cable for us with a hub/switch and a cross over between two xboxs so they are different cables.
