Xbox Modding From Scratch
Discussion in 'Xbox Forums' started by ScoobyZ, Oct 19, 2003.
  1. ScoobyZ
    ScoobyZ
    Sep 29, 2003
    1,016
    +86
    Hi, I am thinking of getting an XBOX when they drop to £99. I am intending to mod myself as I would like to learn how to do it from scratch and also will probably end up doing it for friends too. I have read around and the executer 2.2 lite looks the best and easiest to install. Just a few questions.
    1. Is there a site with an image of all the mame stuff / dashboard software on as I see some people pre bundle it all. Would be handy to put a larger hard drive in and image across all the files ? If not where is the best place to get neccessary files.
    2. Does the box need any cutting to install the switch to flick it back to normal mode ?
    I was going to buy a pre-mod box, but I can get a 120gb HD for about £60 (trade) and the chip is about £30 so that will be £190 for a 120gb chipped box.
    Thanks in advance.
    Scooby
  2. Keitaro
    Keitaro
    Some HDDs aren't compatable, and can overheat...
    Best thing to do, is contact [email protected] on the rllmuk.com forum (it's down at the mo).
    He's done close to a hundred, with a switch, and has been very good. :)
