Xbox modchip where from and which one??
Discussion in 'Xbox Forums' started by Adrenochrome, Mar 28, 2005.
  1. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    As above does anyone know of anywhere in Central Scotland that will chip my x-box and which chip i should get?
    Adrenochrome.
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
  3. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
  4. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    I've got an Xecuter in mine personally and I've no complaints.
  5. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    What version is your xbox? If you Pm me the serial and manufacture date I can make a pretty good guess. If you have a 1.6 then the only sensible chip for you is the Xenium SPICE, Ive installed plenty of regular Xeniums with no hassle what so ever, their solderless adapters are rated very highly (SPICE and normal slderless).
  6. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    I am pretty sure you have a 1.1 xbox, is the easiest version to chip so you will definitely be ok doing it yourself. I always buy Xeniums from www.divineo.co.uk because they are the best functionality for value but its up to you. Xecuter 3 does have a few extras (that some people may use). Ultimately any solderless chip will do everything you need it to so shopping on value is [erfectly possible.
  7. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,232
    Middlesbrough
    +140
    I installed the Xenium SPice chip myself last week.
    Installing the chip takes about 30 minutes, all you need is a steady
    hand and a bit of patience. Easy.
    I had a few other problems, but none related to the chip.........
    Just my Noobness............. :)
    The people on this forum will keep you right.
    Johnny.
