XBox mod Xenium & best Cable
Discussion in 'Xbox Forums' started by LiquidTV, Oct 10, 2004.
  1. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    Guys,
    I know there are numerous threads but would like a couple of simple questions answered.
    If a mod my Xbox with the Xenium chip & purchase the hi-def kit for my PAL Xbox will I will able to obtain hi def pictures using UK PAL discs??
    If possible what is the best site for purchasing either & how easy is it to connect etc.
    Also, what do you recommend as the best Xbox cable to connect to an LCD & will enable 5.1.
  2. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Check your PM mate I can sort you out I am doing a modding service for £35 inc std return post.
  3. bluesteel
    bluesteel
    Sep 19, 2004
    652
    +20
    use this guy he is flawless
