Xbox Mod query by a technical numptie
Discussion in 'Xbox Forums' started by rimibar, Mar 23, 2005.
  1. rimibar
    rimibar
    May 17, 2003
    427
    Cambridge
    +4
    :confused: I will soon be upgrading to a new projector which has a native resolution of 1280 x 720. My Xbox is not modded and I would like to ask you all what I should be doing with it.
    FYI I already have the hi-def pack that feeds into the PJ via component, but like I said the hardware is totally standard.
    Can you tell me if it's possible to make a cool hardware upgrade to get awesome pictures out of it? Also - can the hi res be used on all games or are there exceptions?
    As the subject says - I could do with upgrading my knowledge!
  2. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    do you have a z3?
    you can use component but wont get progressive image but a good image.
    to get progressive you need to mod your xbox.
    i am in exactly the same boat as you and I am about to softmod my xbox.
    NB -i have not done any of this but just read it for the time being.
