Xbox Mod Chips
Discussion in 'Xbox Forums' started by Big_Si, May 11, 2005.
  1. Big_Si
    Big_Si
    Apr 26, 2005
    45
    Bolton
    i am wanting to buy a mod chip for my xbox but want something that is still going to allow me to play online and is pretty easy to install. Any suggestions will be appreciated :confused:
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    Depends on your xbox versions but buying the Xenium S.P.I.C.E from www.divineo.co.uk is a great buy, has tons of features, easy to install and fully compatable with XBL.
  3. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    522
    North Cotswolds
    +3
    I used a Xenium ICE and found it very easy to install. There's some nice PDF files with instructions from the web. Providing you take your time they were very good.
    My friends used Xecuter 3's and they were easy enough too (as long as you don't want to use Hard drive and network LEDs because they require soldering).
  4. Big_Si
    Big_Si
    Apr 26, 2005
    45
    Bolton
    Great stuff had a look at the web site cheers for that. One other thing though before i order one. May sound stupid but how do i find the version my xbox is?
  5. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    if you PM me your serial number and manufacture date I can tell you with a decent amount of certainty. This site will tell you if your xbox is an old version, but if its a newer model its slightly harder to tell.
    http://www.xbox-linux.org/Xbox_Versions_HOWTO
  6. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    Forgot to say www.xbox-scene.com has an excellent version checker, but it normally requires that you take your xbox apart. Which you may not want to do untill your chip turns up.
  7. fatwreckpunk
    fatwreckpunk
    i got a solderless xecuter 2.6 for £30 from www.kanection.co.uk. These are good chips and easy to install. They are very helpful if you get stuck installing
  8. msrx7mh3
    msrx7mh3
    Jul 2, 2003
    993
    London
    +11
    If you odn't mind soldering I'd get a duo x2 modchip- relatively straight forward to install and cheap but reliable- which is good considering that for all the fancy multi-bios features other chips have, most users won't ever use the additional bioses!
    It's also very easy to disable the chip to play xbox live (just switch on using the big eject button- hey presto!).
  9. xboxperson
    xboxperson
    Hi, im just ordered a modchip, but i'm wondering, will a uk modchip work on a
    canadian xbox? please reply :confused: :confused: :confused: :lease:
    if it's not im screwed :suicide:
