Xbox Mod chip HD questions
choccy
I am looking to get an xbox that I can play backups on and output Hidef to my soon to arrive panny ae900 (I hope).
As I understand it if I softmod then I can't play on live.
If I purchased an Xecuter 2.6 CE Mod Chip & Xapter then would that allow the play of backups as soon as installed ? also, does this just reuqire a softmod to then play hidef ? If so can this be turned off and on easily so I could go onto live.
Basically what is the easiest way to have an xbox be able to play backups, divx, output hidef and sometimes play on live ?
I have looked and read a lot but there are a lot of ideas out there and any help would be appreciated.
scumball
You can softmod using SID 4.5 and if you keep your existing Xbox Hard Drive in then you can still use Live. You boot with the Eject button for modded and power button for original use. Obviously no backups on Live...
You can do all this with chips too...that's probably easier but more expensive.
choccy
Wow that's easy. Thank you for the link. I don't suppose you know if this would also enable the hidef to be used ?
So if you were to add a new hard drive, is it easy to set on up and I assume if you wanted to play on Live you could just swap them as it takes only a couple of minutes ?
scumball
To enable HiDef you have to turn the Xbox into a NTSC Xbox - to do this you have to run the homebrew programme Enigmah VideoSwitch - which can only be run on a modded Xbox. You also have to have the HiDef kit plugged in to get the HiDef options on the Xbox dashboard.
Changing a drive is pretty straighforward, I think you do this using the AID disk linked to before, or other disks can be found that may be better...Slayers etc.
triplea4uk
Upgrading hard drive with softmod isn't really that easy involves using PC with XB it's hard if your a newbie.
choccy
am i right in thinking that for splinter cell you cannot use the classics version ? is that the same for the other games ?
Similar threads
