xbox live wireless question
Discussion in 'Xbox Forums' started by Timmy B, Jan 10, 2003.
  1. Timmy B
    Timmy B
    I was thinking of pluging my xbox into my laptop which has a wireless card networked to a wireless usb adaptor upstairs where my desktop pc (and adsl modem) is.
    Will this work? If I can use the laptop to access the internet through ics then I should be able to just plug the xbox into the laptops network card, right?
    Please dont tell me I need one of those expensive router things!
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +646
    cant see a problem with that at all.
  3. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    It should work but it might be a bit laggy - check out the WET11 on linksys's website for an alternative, i've got one and its the dogs.
