Xbox Live - Which Router ?
Discussion in 'Xbox Forums' started by jerkyboy, Apr 20, 2003.
  1. jerkyboy
    jerkyboy
    Getting Broadband next week, and plan to share connection with Xbox and PC.
    Any recommendations for Routers.
    I dont need wireless, just a good reliable, easy to setup up Router.
    I have in mind the LINKSYS BEFSR41.
    Thanks for any help.
  2. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    I got a belkin 4 port router and it setup with XP no problem at all, just plugged everything in turned it on, followed the instructions and away it went.
    There were two paths that could be followed through the instructions though and one looked more complicated, luckily I was able to go the easy route.
  3. jerkyboy
    jerkyboy
    Just ordered a Linksys BEFSR41 (£50 Amazon).
    Do I need to get three Cat 5 Ethernet cables ?.
    Is it easy to set up ?
    Anyone know of any problems ?
  4. colesy
    colesy
    Dec 28, 2001
    729
    +16
    I have a linksys befw11s4 wireless router and it came with 1 ethernet cable. I have NTL and that was supplied with an ethernet cable and a usb cable.
    The linksys ethernet cable is oly about 6 inches long, but the two cables suplied with the ntl modem are about 1 metre.
  5. graham.myers
    graham.myers
    Mar 11, 2003
    6,230
    Leeds
    +931
    I too have the same wireless setup as colesy :thumbsup surfing in the loung on my laptop is great!
    If you have nice BT chappie installing your broadband (I had a rare nice NTL chappie) get him to make up a cable for you. The NTL guy cabled me up an 8meter cable from my cable modem to the router wt the back of the room on top of my DVD shelves
    any cat 5 / cat 5e cable should do but make sure yo udont get crossover cables
  6. Latman
    Latman
    May 18, 2002
    279
    +3
  7. mikeq
    mikeq
    Had a look at that one Latman but decided to go for the Linksys WET11 Here
    which I think worked out a couple of pound cheaper. It works flawlessly.
    Mike
