Xbox Live update problem
Discussion in 'Xbox Forums' started by Waser, Jul 1, 2004.
  1. Waser
    Waser
    Mar 1, 2004
    1,043
    Purley, Surrey
    +75
    I am hoping someone can help me. I have a modded Xbox with a dual boot OS. I recently tried to get onto Xbox live with my chip disabled and I was notified a dashboard update is needed. When my Xbox reboots I get a message saying that there is not enough space on the hard disk to perform the update. Any ideas on how to resolve this problem?
    :lease:
  2. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    Have you got any game saves you can delete to free up some space
    but i think you main problem sounds like you need a bigger HD as there are always gonna be updates and if you manage to squeeze this one on you will have no game save space and future updates
  3. Waser
    Waser
    Mar 1, 2004
    1,043
    Purley, Surrey
    +75
    Hi UncagedTyphoon,
    Thanks for the response. I will have to have a look at it tonight but I'm not sure what's going on. I have a 40gig HDD already that was professionally partitioned when I had it modded. So unless the saved games have built up over time I'm baffeled why this error is ocurring.
  4. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    Where abouts are your Applications saved (XBMC, Boxplorer etc?)...
    The system partition is C:/, and should (ideally) only contain dashboard information - there's usually buckets of space left over even once you have 2/3 different dashboards on there.
    All Games/Music/Applications should be saved on the E:/ partition - if you've inadvertently saved some things on C:/ instead, this could explain the error :)
    K.
  5. kelvin
    kelvin
    Apr 22, 2002
    1,598
    +45
    This shouldn't effect a dashboard update as all Game Saves are on the E:/ partition too :confused: 40 gigs is plenty big enough...
    K.
  6. Waser
    Waser
    Mar 1, 2004
    1,043
    Purley, Surrey
    +75
    Thanks Kelvin, like I say I'll check tonight. I was just interested if anyone had come across this and it turned out to be a serious issue. If it is just a case of managing space on the C partition then I'll sort it out tonight.
    Just to clarify the Dashboard update uses the C partition right? Any ideas how much space the latest update requires?
  7. kelvin
    kelvin
    Apr 22, 2002
    1,598
    +45
    No problem,
    I'm sure you'll find it's just something simple. And yes, the dashboard update uses the C:/ partition - I couldn't tell you how big it is though.
    Good luck, post back on here if you have any problems.
    K.
  8. Waser
    Waser
    Mar 1, 2004
    1,043
    Purley, Surrey
    +75
    Cheers Kelvin, I'll post back if I have any probs sorting this out.
  9. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    wasnt sur on the hd size but i agree 40gig is huge in the concept that it is an xbox
    should be plenty
