xbox live problems
Discussion in 'Xbox Forums' started by Rylan, Dec 13, 2004.
  1. Rylan
    Rylan
    hi,
    I have wired up my xbox through my pc using an ethernet crossover cable ( windows ics connection) because my modem will only connect to my pc and not straight into my xbox.
    I have had instructions that just turn on your xbox and press ocnnect and it should work straight away ( it doesnt). I have also had indstruction to go to my network setting on my pc and click "enable network sharing" , and it still doesnt work.
    when i connect it says cables are connected fine, but then it says "no dns server adresses were recieved from the dhcp or pppoe server. enter the dns servers provided by your isp in netowrk settings". i am using ozemail and they seem to not be very useful but they say my modem supports xbox live and they do too.
    i also went on the xbox live site and looked up what there errors mean, and let me tell you somthing , i know nothing about computers so all their tech junk means nothing to me... so can anyone (a real person) give me any suggestions as to what im doing wrong? or write down some things you have done that i might be able to try? thanks allot.
    Rylan
  2. MrBurns
    MrBurns
    I had the same problem, using ics and aol broadband. I have phoned microsoft and they couldn't solve the problem, so i just gave up. If u manage to get it working tell me plz. I got as far as "cables connected" but i could not get an ip address.
    Anyway trying to set up xbox live using interent connection sharing is a nightmare, so u might want to try and get a specialist in or something. :(
  3. bigNeil
    bigNeil
    Jul 30, 2004
    237
    +5
    Hi guys,
    if you want to solve this, I definitely recommend going to http://forums.xbox.com/ and do a search there. If that doesn't work, start a post called 'Ceesar, can you help me please!' in the UK Live forum, as Ceesar is the networking guru and seems to know everything about this sort of stuff!
