xbox live problem...please help in anyway
Discussion in 'Xbox Forums' started by mattyuk1987, May 3, 2007.
  1. mattyuk1987
    mattyuk1987
    right, heres the deal!
    whenever i go onto xbox live i can connect to a game perfectly through the quick match version but when i come to play my mate by creating a match it keeps saying "failed to connect". why is this. out of the 20 times i've tried, its worked twice. its quite annoying
    can anyone help me??
    firewall is off on the computer where the router is as well
  2. fantazia92
    fantazia92
    Oct 6, 2006
    122
    16
    Surrey
    Check your NAT status by running the Test Connection on the xbox- is it Moderate or strict? If so, this maybe causing the problem as it often doesnt let you connect to friends if that is the status... You need the NAT to be OPEN
