xbox live ntl help
Discussion in 'Cable TV & Virgin Media TV' started by jigi, Jan 2, 2005.
  1. jigi
    jigi
    I have got broadband wiv ntl and am tryin to connect to xb live directly from my ntl cable box(not a modem)to my xbox.but it says cannot connect to xb live.I would like to know, if i have to get more expensive xb live package wiv ntl[ :D
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Is this a new NTL installation ? If so you need to initialise the connection with a PC.
    However if you connect a PC directly to your cable modem it will remember the PC mac address and only allow that single PC to connect until it times out after about 6 hours I think. If you are swapping between a PC and Xbox connected you will either need to go through ICS on your PC (xbox.com tells you how to do this) or get a router to share your connection.
    If you only have an xbox then you'll probably need to purchase NTL's Xbox live kit.
