Xbox live Marketplace unavailable????
Discussion in 'Xbox Forums' started by MarlonSays, Sep 11, 2007.
  1. MarlonSays
    MarlonSays
    Jan 30, 2007
    381
    28
    +35
    Hi All
    Been busy working and with a house move, so not been on live for what now seems like ages!!
    Anyway, I've moved house and between Orange and BT they've finally managed to connect my broadband allowing me to access live. Only thing is, when I go to the Marketplace bit on the dashboard it's constantly saying "Xbox Live Marketplace is currently unavailable, please try again later".
    My connection is fine, I can get on live, the system test is showing all okay and I can even access downloadable material via the options of the game menu when signed in to live, but this message won't budge!
    Any thoughts anyone please????:confused::confused::confused::confused:
    Dave
  2. kopchoir
    kopchoir
    Jan 13, 2007
    25,220
    Anfield Theatre of Reality
    +5,455
    whenwas you last online as there my have been a console update but cant be sure when it was and depends when you was last online dunno if it could be that
  3. MarlonSays
    MarlonSays
    Jan 30, 2007
    381
    28
    +35
    Was on the other day, no update though...
  4. BurninVermin
    BurninVermin
    May 9, 2002
    475
    28
    +38
    If you are still struggling then I suggest that you go into the system blade, then memory, then system memory. Select the marketplace data file and delete it, reboot your Xbox and you should then have the market place up and running again. Happened to me a couple of weeks ago and after a call to MS thats what they told me to do, worked a treat.
