Xbox Live :: Just a few questions.
Discussion in 'Xbox Forums' started by Patrick_A, Nov 22, 2004.
  1. Patrick_A
    Patrick_A
    Hey people,
    If i were to set up Xbox Live, would it matter if instead of High-Speed internet I have Light-Speed cable internet? Would it affect my gaming experience while online? Would the games I play begin to lag and or freeze?
    Thanks in advance
    Patrick
  2. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,927
    2
    Manchester
    +4,450
    The quality of the experience you have on Live (technically speaking) is related to the speed of your connection. I am led to believe you can get away with something like NTL's lowest service of 300k, but I would not recommend going lower than that.
    Plus if you use such a restricted service, I would suggest you shouldn't host any rooms. This might not bother you, however, it just depends on what you want to do.
  3. Pooon
    Pooon
    Dec 26, 2002
    7,345
    Canterbury, Kent
    +935
    I used to play on live using an ISDN connection(128k). I worked really well for games that don't requite a lot of bandwith, project gotham, splinter cell etc. but it was horrible for games where connection speed is important like R63, Top Spin etc. So if your using a 300k connection you should be ok. It'll be quick enought to shoot Lorenzini on Halo2 anyway!
  4. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,927
    2
    Manchester
    +4,450
    To be fair, you'd only need a 56k modem for that :p
  5. Azrikam
    Azrikam
    I think Live "officially" supports connections from 256k down/128k up. Any less and you'll probably get lag, depending on the intensity of the game in question. But obviously, the faster your connection, the better. (up to a certain point, anyway)
  6. Pooon
    Pooon
    Dec 26, 2002
    7,345
    Canterbury, Kent
    +935
    Now where did i leave that 14.4kbps fax modem....................................
    Oh and sorry about disapearing on Sunday night, will be on again on Tuesday night after the football if your about for a game.
