Xbox Live is now Xbox Dead
Discussion in 'Xbox Forums' started by hOwLa, Dec 22, 2003.
  1. hOwLa
    hOwLa
    Need help, my partner has switched my Xbox on with the mod chip switched on and the Xbox was set to auto sign in for Live and it no longer connects. I get an error displaying unable to connect to Live and when I troubleshoot the connection it displays "Modified Xbox error" - any ideas or do I have to go and buy a new one :confused:
    Any positive help will be appreciated
  2. Sly
    Sly
    Apr 28, 2002
    1,465
    west mids,England.
    +48
    oops!
    :nono:
  3. zap
    zap
    May 19, 2001
    267
    U.K.
    +3
    This can be overcome you need to look in the right places.
  4. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
    And the right places are ?
  5. phenom2003
    phenom2003
  6. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    You have 4 options.
    1. Buy a new Xbox
    2. Buy and fit a new motherboard
    3. Swap Xbox / motherboard with someone else who will never go on Live
    4. Change the identity of your Xbox (using the link above)
    When you do get this fixed I suggest you do 2 things.
    1. Ensure Auto Sign In is switched off.
    2. Because that is not foolproof, I would strongly suggest you fit a 'push to make' switch. This means it is impossible to switch you Xbox on with chip enabled unless you mean to.
    Good luck.
  7. thestorm
    thestorm
    Jul 13, 2000
    518
    East London, UK
    +8
    How do you disable auto sign on on the xbox?
    its more convenient to be online when i actually want to be
    online.
  8. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Watch out a new patch released last week detects modded hard drives even with the mod chip disabled!
  9. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    Oh shoot. That's a bu99er. Can see a new XBox purchase on the cards :(
  10. hOwLa
    hOwLa
    I've managed to get a new Eprom from my mates Xbox which will never go online as he has the old mod chip fitted which can't be disabled. I've ran an account recovery and I'm now back on live - for the moment....
    Thanks for all the reply's guys I guess we will just have to wait and see if this new patch detects the modded hard drives
  11. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    636
    +16
    Neil, any more info on this? Any links?
    Cheers!
